TelePaul
J to the R O C
jonnyc said:I still say the head version thru a lower wattage 4x12 cabinet
That'd be overkill in terms of recoridng IMO.
TelePaul said:That'd be overkill in terms of recoridng IMO.
jonnyc said:That depends a lot on what you're going for. As knowledgable as you are you should know that. Thru a 4x12 you get a little more clean before the breakup which can be a good thing, and on the flip side you can push a 1x12 to a more distorted sound. I have both a 4x12 and a 1x12 with identical speakers and the 4x12 sounds huge when recorded while the 1x12 sounds kind of small and thin. So if you need a nice fat rock sound the 4x12 IMO will get you closer than a 1x12. However for some of the bluesier stuff I've done thru the 1x12 was really nice. Why would you think a 4x12 is overkill for recording? Do you have any idea how many 4x12 cabinets have been used in the recording process over the years?
TelePaul said:I'm not gonna record a 4 x 12 cab in my home studio. I just don''t think its practical to be honest. If I want a thicker sound, I'll double track and maybe tweak the EQ second time round. Double these up, pan left and right.
This reminds me of the time Paul Gilbert tracked 100 guitars on one song...after 10, there was no discernible difference in the sound. Seems alot of kids do this; buy their 100 watt head and half stack but can only run it on master 3 in their bedrooms without some kind of attenuator.
RideTheCrash said:Well I could run the combo out to a separate cab later if I wanted to, right?
jonnyc said:Well you can argue all you want but a 4x12 sounds different than a 1x12. I have both and record both all the time. And 30-20, nobodies arguing about wattage, it's about how many speakers to use. We're all talking about a VJ here. BTW the VJ thru the 1x12 isn't that much more quiet than running it thru a 4x12 so I'm failing to see how it wouldn't be practical, in fact I pretty much run it at the same volume no matter what type of cab it's going thru.
TelePaul said:I'm not argueing man, its all good, just voicing opinions. And no its not about wattage, but it is about volume I guess. Think 32-20 meant low wattage works for recording for the reasons I voiced. I'd consider a 12' speaker just because the treble from an 8'' with a Telecaster would take your head off.
soundchaser59 said:The VJ combo has one 4-ohm speaker output jack on the back. The cord that connects the internal speaker just hangs there like a dongle. You can connect the internal speaker or you can use your own cord and plug into a 4 ohm cab of any size. It will drive an 8 ohm speaker, but it loses a lot of its smooth scream if you do that. The head version has one jack with switchable impedance.
soundchaser59 said:Nobody has them in stock right now.
RideTheCrash said:Musicians Friend says they have them in stock, but what do I know?
Unfortunately living in Canada and all, it's easier and cheaper for me to purchase here rather than going through the hassles of shipping and border charges, etc.
