its not me, its the LE talking...
  • Thread starter Thread starter queenin3d
Q
queenin3d
Hello there,
I have been experiencing a problem for some time with the Mbox2 Pro being recognised by my macbook pro system. I am running Pro tools 8 which came with the MBox2 Pro Factory bundle. The Mbox LED is always flashing stating unrecognised from the software when going to launch.
At times it has worked but very shortly afterward it will again say unable to recognise, I have tried restarting and disconnecting, using the power supply adapter or just the firewire cable independently and reinstalling…
I did notice recently that there was two icons in the system preferences tray, one for mbox2 pro and another for mbox2 pro factory, i removed the mbox2 pro leaving the factory and still had no joy…. i have now removed both to see if the firmware can reset but nothing…
Sorry for the very long message, it is difficult to explain, I have tried a lot of solutions from other peoples thread on this forum and other ones but still can not seem to resolve.
If anybody can offer some help or guidance I will be very appreciative, this has been bought from new months ago and still not been used, I really want to get set up and running.
Operating System - OSX Version 10.6 Snow Leopard
Pro Tools Version 8.0
MacBook Pro 2.16 Ghz Intel Core 2 Duo - Memory 2 GB MHz DDR2 SDRAM
Thank you in advance.
OK if you haven't done so already you will need to download the Pro Tools 8.x.x update pre-release which brings support for Snow Leopard.
The only other thought I have is, are you using the original firewire cable?
hello pezking,
thank you for the speedy response... i have now updated pro tools to 8.3 and snow leopard to 6.3 but still pro tool is not recognizing the hardware when it is definitely connected with the original firewire cable also... urggggh oh but the flashing light has now stopped it is just on instead...
so annoying, have been trying for sooo long now...
i had the same problem on the following.
new mxbox2-usb to MBP with PT8.3 and Snow 10.6.4
PT would load up then say 'cannot connect to digidesign hardware...OK or CANCEL'
Another symptom was that the mbox2 prefpane in system preferences would say unable to connect,
I found a post somewhere that told me to download the latest pace extensions (even though there's no ilok involved) and the standalone digi core audio drivers.
not sure which of the two fixed the problem,,,but it's fixed
