E
estring
A while ago I was recording all fine and dandy. Then one day I went to playback and I had this awful screeching with stuttered playback. After much trail and error, and MusicXP.net suggestions. and the many suggestions from you guys , I decided to reload the OS.. yet saving some of my files.
Everything was fine again, recording, playback, effects the whole setup was working great.
About 3 weeks in...bam it all happens again. So this time I do a completely clean install of XP, nothing left behind.
I did not reload my saved files. I just started with some new never recorded ideas.
Again everything works great and I'm hoping this is the last of that problem.
Well that was about 3 weeks ago and today I hit play and there is that awful screeching again. I have tried all of the "obvious" tweaks.
Heres the thing, not only does my recording sound like shit, but the Windows melody that plays when you start your PC,also has crackles in it, as well as any cd that I play through WMP 10.
FYI...
P4 3.0ghz
512ram
samsung 80gig HD
Audiophile 2496
Sonar 4.03
I'm starting to lose hope. Should I get another HD of better quality?
I dont think memory is the issue.
WTF!!!!!!!!
FYI...
P4 3.0ghz
512ram
samsung 80gig HD
Audiophile 2496
Sonar 4.03
WTF!!!!!!!!
There's actually more than one problem that can cause this behaviour. Maybe a hardware incompatibility, or bug in a driver. It'll work for a while, and then at some seemingly random point in time, it pops up. it could also be a defective piece of hardware. You say you don't think it's a memory issue, but it could be. You should definitely get a memory tester program, like docmem, and let it run. It doesn't take that long on these newer systems to see if you have a bad spot somewhere in your ram.
