RideTheCrash
Member
I only solder every now and then so bear with me -- I've had this old Strat kicking around for years and the volume knob has been awful since I got it (well used at that point). I replaced the pickup selector 4 years ago and managed to not mess it up too much. The knob tended to cut in and out randomly if turned down (I usually keep it maxed out at 10 99% of the time).
I had an issue dealing with the grounding, the knob would do almost nothing if I turned it to zero after I soldered a new one in. The ground wire from the trem was not soldered and possibly hadn't been in a long time (still trying to find old pics to confirm) so I figured to solder that to the back of the pot and instead of bending the 3rd lug back, I made a short wire and soldered it from the lug to the back of the pot near where the output wire is and it finally worked.
Now it's not a major issue -- it mostly works but if I turn it to zero and give it a little jiggle the sound usually cuts back in and the knob will stop functioning properly until I jiggle it some more and it goes back. I'm assuming this is a result of my soldering and a bad joint but I just wanted to confirm the little wire to the 3rd lug thing I did is okay and if there is anything else to consider? I don't *think* I burned the pot but I find it difficult re-soldering some of the wires that are close together on the back of the pot without a bunch of wires coming unsoldered and me trying to grow a third arm to keep it all in place.
