F
Foo-bu
ok i have an old fostex 280 multitracker with 4 tracks and 8 channels. it also has 4 outs on the back as well as a AUX send which i plan on using to send a feed out to a delta 44 which has has 4 inputs. I currently have a sound blaster audigy platnium which has 1 input on it.
Idealy when i mic drums i would like to have each drum as a seperate track using at least 5 mics. I will be using cool edit pro to do the recording.
is there a way of making it so i could turn every drum into a seperate track using what i already have?
i know that the 4 outs on the mixer can go to the inputs on the delta 44 but that leaves out one mic which i think could go to the audigy. would i hafta use the pan options to isolate a certain track? is there a way to bump channels into tracks in real time if i cant send each drum out on its own? I'm new at this so any advice helps! thanks!!!
