I have my monitors hooked up to a receiver that has rca jacks for the line ins. From my mixer I have two 1/4 inch to rca connectors connected to one of those dual rca cable (the kind with a red and a black rca male connector on both ends of it) then it plugs into the receivers line ins.
I've always had troubles with this setup because it seems that the cheap rca cables I buy get bad after a little while and I need to buy new ones, then those go bad (usually one monitor will not have sound coming out of it and I'll have to fiddle around with the rca cables or the 1/4 in to rca connectors) and then it might work for awhile, but it will eventually do the same thing.
My question is are there good quality rca cables that might solve this problem? I suppose I could just buy an amplifier that takes 1/4 connectors. But are there any good rca ones?
I've noticed that there are gold plated (as it says on the package) rca connectors which are usually a few dollars more, would you think these would work better?
