apl
Stand Up Comity
Does a ribbon pre not needing phantom power make it easier to design quiet, ie, can you lower the input impedance?
Or does that make it noisier?
Or does that make it noisier?![]()
Ok, guys...
First off... what transformer are you guys using to go from unbalanced to balanced inputs? I'd love to use the Jensen JT-11-DM, but needless to say its not cheap.
Great link to the jenson schemo! That really simplifies things... I might go for that option, It seems quite logical electronically speaking.
I do have a query though, why would Rane utilise an active balanced line driver stage in the Ms1b, surely the 217 has enough fire power to drive something like the passive circuit in the jenson schematic. This would mean less components therefore less $$$ and I guess that less active components means less noise... So what are the advantages/ disadvantages of active and passive balancing circuits? (sorry for the hijack!)
"Note that INA217 does not "drive" the passive impedance balanced output."
What I meant to say was that the 217 would have no problem supplying sufficient current to drive a load via the passive circuit... That to me would be the only reason to apply an active balancing circuit.
