Blue Bear Sound
Tex......... I didn't CREATE the definition of stereo, I merely repeat it!TexRoadkill said:BlueBear- Why do you always overly complicate the stereo issue? Sometimes you even jump in with the L-R, L+R...
Blue Bear Sound said:Tex......... I didn't CREATE the definition of stereo, I merely repeat it!![]()
I think many engineers would consider them "big mono" -- the general public, OTOH, would think of them as stereo because they simply don't understand the true distinction.chessrock said:Are some of the older Beatles recordings stereo
Not tricky at all.... in the context of compressors, it merely refers the the linking of the 2 channels by a single set of controls (and applying the same settings to both channels). The compressor itself doesn't know what signal is being fed into it!chessrock said:How is the term stereo used when refering to a "stereo compressor?" for instance. It's a tricky question.
Blue Bear Sound said:.... in the context of compressors, it merely refers the the linking of the 2 channels by a single set of controls (and applying the same settings to both channels).
dictionary.com said:stereo
adj : (electronics) designating sound transmission from two sources through two channels [syn: stereophonic, two-channel] n 1: two microphones feed two or more loudspeakers to give a three-dimensional effect to the sound [syn: stereo system, stereophonic system] 2: two photographs taken from slightly different angles that appear three-dimensional when viewed together [syn: stereoscopic picture, stereoscopic photograph]
Source: WordNet ® 1.6, © 1997 Princeton University
statecap said:I have a friend at work that tells me the stereo effect is made simply by use of "panning".
fierojoe said:For all practical purposes, Stereo is not panning, but in essence it is in the fact that you are taking mono instruments (for the most part) and creating a stereo image of them. Take the drumset for example. You have toms panned left-center-right, your cymbals are panned left to right and what happens? You have stereo image. So, in essence stereo is just panning for a lot of things, but not all.
LET THE FLAMES BEGIN!![]()
KingstonRock said:Originally posted by dictionary.com
stereo
Blue Bear Sound said:And as we all know, Mirriam-Webster was RENOWNED for his audio engineering knowledge....![]()
Look up sample rate and word size in the dictionary, and I'm guessing there'll be an equally incomplete definition there as well!
Blue Bear Sound said:Yes Tex... that's absolutely true...!
I guess my point is that "stereo" isn't as straight-forward as simple panning. There is an underlying principle beneath the process and it is useful for people to be aware of - especially in the context of trying to create the illusion of an audio soundstage in front of them....
It is sometimes good to know the WHY, in addition to the HOW!
Originally posted by Blue Bear
Pan a mono signal, and you have a panned mono signal. Pan a stereo signal, and you collpase the stereo field and it becomes, in effect, a mono signal - actually probably less than a mono signal since in collapsing a stereo signal like that, you likely will lose a portion of the signal as part of the L-R will cancel-out some frequencies in the L+R component.
Well... when you have a stereo track, it is by definition 2 separate tracks of information. Now only that, it also has a stereo image defined by the "distinction" of each track -- ie, you can't get a wider image of that signal than panning each channel hard left and right.cordura21 said:So when you record using a stereo miking technique should you pan both resulting tracks to the center, or hard left and hard right? Maybe "should" is a strong world, but is there a correct form and how do you and most of the people do it?
Maybe when you say "pan a stereo signal" you're meaning "pan them to the middle" and I don't understand that. Thanks for the help. Andrés
TexRoadkill said:And that will be the subject of next weeks lesson.![]()
I remember the first time I tried doing ORTF binaural recording with just two 58's and a pillow in between. The first time I played the track (of me walking up to the mics and talking) I turned around to see who was walking up behind me, lol.
Stereo is definately one of the least understood concepts in home recording. I think it will be cool when engineers come up with a system to do true surround recording. I imagine you could do some cool stuff with multiple spaced pairs that were sent to the individual speakers or some type of dual M/S setup.
Right now surround sound understanding is about where stereo was 50yrs ago.
