Is one take a thing of the past?
Hah, I've actually done that before. When I recorded my bass drum with my AT4047, my cymbals bled like crazy, and it was obvious in the full mix, even with the other instruments. Any EQ would audibly affect the cymbals too. So I ended up going through the 4 songs I recorded and edited only the bass hits. The AT4047 is killer on bass drums, but the maintenence was too much for it to be worth it, so I stick with my Beta 52 now.
This. I can see gating toms sometimes, but does anyone actually remove the space between snare or kick hits? That's insanity.
Haha, I like this.
That's basically what I do. I cut out the stuff on the toms I don't want, but usually, I'll just put a gate on the snare or kick hits, depending on the style. If it's jazz, god save me, I'm not going to be able to get the gate to work on the snare, so I just leave it alone. I'm fine with bleed in a jazz setting.
I'm usually gating my kick and snare so I can compress the crap outta them anyway. Most of the people that come to me in town are the hard rockers and metal guys, so they love compression.
Well duh, but I was just wondering. People do some whacked out completely unnecessary stuff in the digital realm.
:D
I know you know that there is tail decay....I was just answering for the folks that might consider doing something that dumb....oooops, sorry Seafroggys. :p ;)
Hey...when I first started messing with DAWs...I did a LOT of dumb things, just becuase I could with a DAW and I couldn't with tape.
The important thing was to realize when something was worth it and when it was dumb...and over time refine my SOP. :)
:D
That's funny, I was kind of the same way, but more in an experimental sense. I've tried lots of silly tricks and procedures, but none of them stick. I tried enough stuff to know that most of it is pointless DAW masturbation. Nowadays I'm more basic than I've ever been. Maybe I've refined my source sounds better? I have a better grasp on my own workflow? I don't know. I just know that I don't hardly do jack shit to my mixes and I think they sound better than ever.
Yeah....I've gone that way too over the years....needing less and less mixing "work" to get the mixing done.
Sometimes I do a song that's not my more typical style, and then I have to consider things I normally don't...but generally, most of my sound/tone work happens during tracking these days.
I could probably even cut out a lot of the edits/comps that I'll do in the DAW, but I sorta settled on one SOP of tracking to tape and then finishing in the DAW, so I just stick with that SOP purely for the comfort zone when I can.
I know which tracks I want 3 takes of and which ones I only want 1 take of...etc..etc.
I must say, working with a female singer lately has forced some rethinking...and I'm even writing some songs for her specifically....so it's a little different, but in a good way.
I could probably even cut out a most of the edits/comps in the DAW, but I sorta settled on one tape-to-DAW SOP, so I just stick with it purely for the comfort zone when I can.
Yeah but can she cook? That's really all that matters.
I should have said, "Not everything is compable to a good enough standard"
No really....give me an example of what could be too difficult to comp.
I'm not saying absolutely every track on every song ever done can be created from comping severak takes....just saying that if you have the multiple takes of any given track...it ain't that hard to edit in/out whatever you want/don't want, and create a very believable comp.
You would not know it was a comp.
That's like the "dark force" of DAWs....:D...and I've used it, and it's almost scary how much you can "save" with DAW tools these days.
So is there a specific Blackmore anecdote concerning a female lead singer....? :)
PS
The female singer and I both like blues/rock....not English Renaissance music. :laughings:
Combo fingerpicked / strummed complex solo multiple miked acoustic guitar played on an opened tuned instrument with resonant strings ringing out without many stops and starts where it's the only instrument being played, isn't being doubled and it's an instrumental.
That's a world away from constant noise rock music which is a lot more forgiving of such editing.
It's a theoretical exercise Miro - you might still disagree with me, but to the best of my knowledge you don't play that style of music, and neither do I much now, but I used to.. :guitar: :D
I don't really comp anything (it just doesn't sound very fun), but I do erase a lot of silent bits from each track just hoping to avoid any unpleasant build up of amp hum and whatnot (I have noisy gear).
Give me three solid takes of that, done in quick succession so the feel is close on all three....and I'm sure I can comp one track from them, using sections from all three, and you won't know where the crossfades are.
Multiple mics are just more tracks/more work...but not any different than single tracks, you just have to nail the crossfades multiple times, and honestly, with multiple mics it can be even easier to mask the crossfades as a whole, and if the music is not constant...that would make it easier, to just find a break in the music above and below the section to comp.
It's only really hard when the three takes are way off from each other...played differently, very poorly, lots of intonation differences.
This is why I feel that good comping isn't about taking bad takes and making them into a good one...it's about taking good takes and comping them into a better one.
That said...there's been times when the takes/sections just don't match up well for reasons I mentioned above, but that's more the fault of the takes, and not so much the comping process. That's why I like to go for at least 3, sometimes 5, takes in quick succession when I know I may want to comp a track. I can usually find good matches for crossfading between 3-5 takes.
Remember the scene in La Bamba when the producer has "Ritchie Valens" do something like 60 takes because each one had to be a perfect match so they could edit and comp to one... :D
It also can be a subjective decision with some types of music/songs/tracks....should you even try comping or should you do the whole thing over, but that's up to each person to decide, I'm just saying that there's a lot of power in a DAW.
My DAW, Samplitude ProX, was built for editing better than most. Its Object editing is second to none, and only now are some other DAWs trying to put out similar functionality, which I've been working with for over 10 years now.
Is one take a thing of the past? Sort of, but it doesn't have to be.
When I'm first creating the song, there will be a lot of cut and paste going on whle I'm arranging everything. After I have the arrangement figured out, I'll learn how to play it all the way through, then I'll record the full passes. The end result usually has more life to it that way. Sure you could just copy Verse 1 to create Verse 2, but the end result can sound rather sterile.
"One take meaning - one track per pass"?
It's arguable that it was always a thing in the past.
I'm of the opinion that if you can't play it all the way through, you're not ready to record it yet.
If we're talking about home recorders recording for fun and never ever going to play those songs live and those songs never going beyond their initial life, I can't see what difference it makes as long as you know all the parts you need to play in the sections you need to play them.
That said, I don't think I've ever written a song that I couldn't play all the way through. I play them all the way through when I'm writing them and running through them for whoever is going to play on it with me.
Back in the day when they kinda had to do a lot of stuff as-it-falls, and "editing" was just a dream into the future....they would rehearse until it was tight, and then go for it. If it didn't work, they *had to* start the whole thing from the beginning, when multi-tracking was yet to be invented or become very common.
It's worth remembering that the days where there was no multitracking and no kind of editing were over before the overwhelming majority of users on this board were even born. And I don't mean those born in the 80s ! Lester Polfus {:laughings:ok, Les Paul !} recorded a number of guitars on the inside and outside bands of acetate discs in 1930 {thereby beginning the process of both layering and multitracking} and the next year,Laurence Tibbet, an opera singer, superimposed his voice on top of his existing vocal on a recording of "The Cuban love song". Granted, the nascent recording industry saw this and Les Paul's multitracking ideas as a novelty at best and it was years before it caught on big time. But it did catch on eventually and there were 8 track recorders in America in the 1950s. The history of recording is fascinating and full of surprizes. By the early 60s, lots of editing was happening. A number of Beatle songs are edits of two separate recordings....and the whole punching in phenomena led to the idea of recording certain bits in sections.
I can see gating toms sometimes, but does anyone actually remove the space between snare or kick hits? That's insanity....
It's certainly a pain in the patootie. Back in 2010 or thereabouts, I was experimenting with various mic set ups on the drums and in a few cases, there was so much bleed on the bass drum mic that in order to get a decent bass drum, I had to cut out anything in between that wasn't a bass drum. It was no fun on a 2 minute song, much less a 13 minute one !
In the end it worked well. But I couldn't keep doing that as a standard thing because much of the fun and joy would go out of recording for me. I remember Dogbreath saying that he spends time cleaning up his snare tracks by cutting out the in between bleed.
What's funny to me is how insanely precise and anal Hard Rock/Metal music has become!
Precision has it's place, Zeppelin, Purple, Sabbath, Quo and the heavy bands 'back then' used precision timing but most importantly, they wrote songs and weren't above being raggy when the need arose. Heavy and hard rock {I define hard rock as heavy metal with the amps set at 9 :D} were the vehicles through which the songs were expressed. They played songs via a style rather than a style via songs {a subtle difference}.
Comping isn't just about fixing mistakes...it's also about matching the right intensity, feel, emotion...etc.
I guess I don't really comp then. Back in the 90s my mate that played drums and I tried it, two or three takes, but it rarely worked with us. What I'd do would be to make an experimental track of the bass and drums out of our takes....that is if we didn't get seized by the moment and improvise in another direction ! I stopped comping after a while and came up with the recording in sections method, if a song wasn't played all the way through in one go. The way I view it, in the relatively short time I'd have to lay down the song and teach it, I'd have to decide if it was feasible to do it in one go. I got tired of those 15~20 minute songs that had some great parts and some duff parts. Far better to concentrate on a section and get it un parfait. Sometimes, that would be one take, sometimes 10. But if the take isn't it, I don't keep it, I just wipe it and go again until it is it.
That said, if I or the vocalist have muffed up part of a vocal but the rest of it was what I want, then I'll do an on the spot comp, but only with a second track. I'm pretty good at knowing what I want as soon as I have it.
I think sometimes our views of the old days are a little skewed.
Alot of that is the fault of writers that tend to push particular angles and agendas rather than the bare facts, almost as though the reader is incapable of reaching conclusions based on what they read.
I'd say that applies or will apply in time to every one of us. But I'd add the caveat that one person's dumb and unnecessary is someone else's preferred and comfort zone. And someone else's straightforward and sensible is someone else's straitjacket of uncreativity.
My joy has long been reading everyone's different ways of in effect reaching the same goal. I find it unwaveringly interesting.
Hey...when I first started messing with DAWs...I did a LOT of dumb things, just because I could with a DAW and I couldn't with tape.
It was reading about the things that could be done digitally that really sold me back in 2004. It was my tape menopause, I was going through the changes......
I still feel that pretty much what can be done digitally was being done with tape in the late 50s and especially the 60s & 70s. But digital has made it quicker and safer which for me = ideal.
Last week, I listened to the original, unedited version of a great song called "All you've got is money" by Grand Funk Railroad on their "Survival" album {it's a bonus track}. That song and I have been bedfellows for 33 years. I love it to bits. The original recording is a few minutes longer and has some great bits not in the album version but in hearing it, I realize what a grand job Terry Knight and the engineer did on the album version. The album version flows beautifully but in hearing the original, it's like two completely different songs. The album version is completely edited together and this, from 1971 and the 'days of tape'. "I me mine", "Bohemian rhapsody" and "Blinded by the light" are further examples of the kind of thing that was happening before digital. They just took a heck of alot longer, that's all.
For me it depends. For example, I get the most satisfactory acoustic guitar I've ever managed with two mics, a crummy bottletop contact mike stuck a few inches from the soundhole and one DI lead straight in, the latter two for some electrified grit and dirt but not so they sound like it. The mics could be in any weird configuration {uptop, behind, at the soundhole, away from it etc}. But it's stuck. Same with getting a mad electric 12 string sound by playing an electro acoustic through two amps simultaneously, using a 58 and condenser. Nice experimental accident. But again, it's stuck. Although I'll use other methods too.
Kazoos. They ain't easy.
It depends on the way you play it and actual piece you play and where the notes fall.
Seriously !
I don't necessarily disagree with that. I'm just a believer in integrity and competence. It's my own hang-up and I don't, well try not to, push it on anyone else. I like knowing that for my own stuff it's all legit. A Greg recording is all real shit really played by me in a way that I could march right out and play it live right in front of your face if I had to. For most of the stuff I listen to, I believe that to be the case as well. I like to think, hope, that I'm listening to stuff that was done in the way I like it to be done. If it wasn't just don't tell me about it.
