IRQs
  • Thread starter Thread starter dobro
dobro
dobro
Gadgetlabs tell me I have to free up one IRQ in my computer in order to install their sound card. I had a look, and my computer's got 15 IRQs, all in use, some of them shared. Assuming the guy at Gadgetlabs knows what he's talking about, and I have to free up one IRQ, does anybody know how to go about this? Or is this a job for the computer tech down at the shop?
First thing you do is print out a list of devices that are using those IRQs. Then you decide which one you can live without while using your soundcard. Then you make these share an IRQ. Overall; not a recommended procedure.... :)
Thanks drstawl - that's what I thought - sharing isn't the best arrangement. I'll let you know how it turns out.
The first thing you should try is to disable one or both comm ports on the motherboard if you have a PS/2 mouse.
Here's the deal:
COM1 uses IRQ4
COM2 uses IRQ3
COM3 uses IRQ4
COM4 uses IRQ3
On occasion you will find some variation here, but the above is standard. Com ports 3 and 4 don't physically exist, but don't worry about that for now.
<ok, this crap can get long-winded so I've snipped a huge explaination and replaced it with the following>
Here's what you do if you have a PS/2 mouse and no serial devices (typical):
Get into your mobo's BIOS setup (hit del at startup usually) and DISABLE BOTH COM ports. Typically with today's applications and better technology (USB, etc), serial ports are unnecessary. Now you should have either IRQ 3 or IRQ 4 available. Hopefully your soundcard can use one of these.
Here's what you do if you have a Serial mouse:
Nothing. Ouch, eh? Your modem is going to hog either IRQ3 or IRQ4 and your mouse will be taking up the other one. (realize that modems are PHYSICAL com ports) Nothing you can do except get a PS/2 mouse (if your machine is capable) or get rid of the modem. :(
Some modems, especially 56K Winmodems, will hog 2 IRQs. They do some funky shit that the older modems do not. One thing you might try is to get rid of your fancy modem and find an older 33.6, which might turn out to be just as fast on standard telephone lines. (56K means little in the real world)
Another thing you can try is to look for devices that you aren't using that may be using up IRQ's. "If they're there, why ain't I using 'em?" Well, my motherboard comes with an additional ATA/66 controller built in. Now, since that's the ONLY controller I'm using, I can disable the other standard UDMA/33 controller (unless I ever have more than 4 devices).
Don't print? Don't have a parallel drive? Disable the parallel port which uses, I believe, IRQ 7. (this one is pretty standard so some devices won't let you set them to IRQ 7).
Slackmaster 2000
why not just yank your old pci soundcard and put in the new one ?
- eddie -
Slackmaster - I'm not going to bore you with the way in which my system varies from what you described, but you've told me enough to go on. Thanks for the education.
Eddie - good idea, too. Ain't simplicity beautiful?
Cheers, volunteers. I think I can make this work, so it's time to order my new sound card now. If I finally get this system up and working, I think I'll have t-shirts made. :)
nice discussion.....i asked someone at ardvaark whether i'd need an irq for their new direct pro card, and the guy said it wouldn't need one.......is this possible? perhaps, i misunderstood him....
nero-
The standard reply from someone on a tech support staff when you ask them if you need something that they know nothing about is "No, I don't think so." :)
So, either he meant that the card doesn't require an ADDITIONAL IRQ (e.g. it's standard), or he thought you were drunk and trying to say "I like you", or was unable to find "IRQ" in his "Manual of Things to Say When You Don't Know Anything About Our Product", or you weren't making yourself clear.
I suppose it is possible that the soundcard in question uses some newfangled technology that doesn't require an IRQ, but I wouldn't bank on it. Is it a standalone "soundcard" or some kind of expansion/add-on type of thing?
(BTW, I really shouldn't knock tech support staff as it's usually not thier fault that they are, in many cases, under-trained.)
~~Slackmaster~~ My computer yells illegal when I SIT... so next month when I get a new one, and you are passing through San Diego....
