I found under "Pre" how to rotate 180 degrees, but that's not the same as inverting the signal.
Cubase 7.
How do you invert the polarity on an FX-channel?
Best regards
-paw
Thanks for the tip Steenamaroo, didn't think of that!
At what frequency?A 180 degree rotation is a signal displacement of half a cycle.
If the function called "180 degrees" really is phase inversion, then they are using the wrong terminology, and Steinberg should know better!
Yes it is the phase inversion, if you open the Channel Settings window for the FX channel you will still see the old ⊘ phase inversion symbol.
Best regards,
GN
Did you try it to see?
At what frequency?
Phase can't be inverted, even with a perfect sinewave.
Phase can be shifted (time adjustment) and polarity can be inverted (static adjustment).
If Steinberg is really offering a tool to adjust phase by a half cycle, there would be an option to choose a reference frequency.
Plus, I can't think of any reason to have such a tool. Maybe that's just me though.
Hello paw1,
Best regards,
GN
Didn't need to as I got the answer from Guillermo N.
Hello paw1,
Best regards,
GN
"Yes, we used the wrong terminology", or "Yes, we meant what we said"?
Not being awkward but saying it's phase inversion doesn't really clarify anything.
Seriously?
Does the button invert polarity, or what?
What does the button do?
According to your link, then the name should be changed...
But what it does: It inverts the polarity of the signal.
Best regards,
GN
