Well, not quite. The system he was using is not the same as true equal temperament (which came about as a result of modern measurment techniques), but it is certainly the same basic idea. There have been many different temperament systems over the years, and equal temperament is actually relatively new, within the last 100 years or so, if I remember correctly (it's been a while since my music history class).
As to Nicole's original question, most modern one piece bridges have little allen screws right behind the posts to give you a bit of overall intonation adjustment. If you use a standard gauge set (i.e., mediums, lights, etc., but not "custom lights" or "thick top, heavy bottom"), once you get the two E strings right on, the others will usually be very close, but this all assumes that the bridge is in the right place to begin with, which is not always a safe assumption with a Gibson.
Light
"Cowards can never be moral."
M.K. Gandhi
