T
Tappy
I was looking at getting a computer to do recording. What is the best to go with, Intel or AMD? I heard that AMD was better for music.
ds21 said:It's like asking Chevy or Ford...both will do fine the Intel will cost you more but they are the fastest for now(I'm just talking the common type cpu) I used to use Intel but now I use AMD no problems so far, your safest bet is to copy someones system that uses the same hardware/software your going to use. BTW Chevy is much better![]()
Polaris20 said:Who me? Nope.
I was just throwing that out there for another option for a DAW. [sarcasm]I hear they're very good!
[/sarcasm]ozraves said:
And, this is the reason I prefer Intel because I love the Intel motherboards. They aren't the sexiest mobos but the are so stable and so easy to update.
So do Intel cpus. And it's not that one is running considerably hotter than the other. They both run HOT.ozraves said:The only problem with AMD cpus is that the do run hot
My P4 even overclocked only hits about 110 to 120 degrees, much cooler than P3s that I have worked on. You still need a good fan, I'm running a Vantec. There are ways to overcome having to use a loud fan, like water cooling. Swiftech makes some good stuff: http://www.swiftnets.com/christiaan said:So do Intel cpus. And it's not that one is running considerably hotter than the other. They both run HOT.
