Stogie_D
Mornin all, I'm looking for an answer to a insert question with no luck after much searching. Thought I would pose it here with you electronics folks. I have recently upgraded my analog studio & have run every piece of outboard gear through patchbays. Access to the rear of the mixer is, as usual, a pain. I have put a 16 channel insert snake from board to the Compressor / EQ rack patchbay. At this point, I HAVE to have each channel I'm recording on inserted through a processor wether I'm using it or not to get signal. I just leave them in bypass mode. What I would like is this - a TRS jack I can plug into the patchbay that loops the signal back to the board, ie, eliminates the need to go through a bypassed processor. As a TRS is send / return, can I wire the send to the return inside the jack & call it a day. If I have not explained this in a understandable manner, please ask for more.
Thanks all,
D.
Thanks all,
D.
