M
Mike Freze
Hello. I've asked a few questions before about input levels and the responses were really helpful. Now I am confused about another area with level balances in the signal chain.
I understand that you need to get as high an input level as possible when recording without going over that 0dB threshhold (to avoid clipping, distortion, to get the best signal-to-noise ratio, etc.) No problem. That means adjustments from the guitar volume knob to the amp volume knobs then to the input levels on the audio interface. OK.
I even understand that sometimes you might want to record those input levels a bit below what you could max out at if you plan to have dynamic variation in a song (raising an instrument or lead vocal during the chorus, for instance, but still not distorting the raised signal); then you can move the volume up or down through the ebb and flow of your song for one or all instruments.
Here's my question: oftentimes I have my levels through the signal chain set just right: no distortion, no clipping, then I get to my virtual mixer and play back what I recorded (or record on the spot) and the meters sometimes jump to the red when no red appeared on my interface after adjusting the earlier stages in the chain.
Why would it do so in the mixer?? Shouldn't the mixer reflect exactly what I set before it reached the computer recording software? If I turn doen the level sliders when red appears in the meters to get it doen in the green, then of course what I record will be weaker (quieter) tracks than I wanted.
Do you have to turn these level sliders down anyway? Is it a compromise you make between strong input signals earlier in the chain and the end of the chain (your mixer level readings??) Or does the level sliders/level meter just reflect what you will hear when you play back what you already recorded without affecting the levels you set for that recording? Seems to me that if I left the level sliders alone, let them go in the red, it stays that when when I save my prject: the red pops out as a part of the record; again, if I lower them down, then it defeats the purpose of having my original signals boosted up because now I'm forced to turn the signals down.
By the way: is the "channel level" I see in my mixer (I use Cubase LE) the same thing as my adjustments with the level sliders?
Mike Freze
Mike Freze
