SMX_Dizzy
I just received a LaCie D2 Quadra 500gb external drive to use mainly with PT (about 90% PT, 10% Reason). I am running PT M-Powered 7.4 with an M-Audio 1814 as my interface. I have 2 questions about it:
1) I moved my PT folder containing all of my session data to the LaCie, to remove it from my main/internal hdd. After I open a session that I moved to the external, when I go to play it, the stop button is solid and the play button begins to flash. Seconds later, "You are running out of CPU power. Remove some RTAS plug-ins or increase the CPU Usage Limit in the Playback Engine dialog. (-9128)" appears. Also, during that process, my speakers pop/crackle with none of the actual audio coming out. This problem never happened to me before I started using the external.
2) How do I set the external to be the main recording drive? I no longer have a need to record to the internal, so is there a way to set it up so that it automatically knows I will be recording to it?
Sorry, I'm new to externals and all the peripherals that go along with them. I appreciate any help. Thanks.
