R
rockinokie
Hey! New guy here.
I just aquired an MX-5050 MKIII-8 after being inspired by a Space Echo (tape delay) I picked up a while back. There is not much that I listen to that wasn't recorded on tape and also being a musician I figured I could really get into this.
So here is the low down:
Other than the corners of the machine being a little beat up it looks barely used. I power it up and everything lights up like it should but there are some slight problems. It plays slow when the take up reel has the majority of the tape. It rewinds slow when the supply reel has the majority and ff slow when the take up reel has majority of tape. It came with a couple reels of Ampex 456 mastering tape and an Ampex 206? test tape. So here are some questions:
1. What else can I do besides get different tape? Oil capstan motor? I know I need to clean it gooood.
2. I understand that these machines have an unbalanced signal and are pin 3 hot. The guy I got it from said the only time he used it was when he ran an xlr from a cd deck to record and check signal. He said it recorded and played back and said that his cables are pin 2 hot. He said he was aware of them being pin 3 hot so he assumed it had been modified. Likely??
3. Before I can do anything I need a mixer and maybe some pre-amps. I was told to get an older yamaha mixer. Suggestions? and yes, I know there is plenty I can do before I get a mixer.
I have a ways to go and know very little about this stuff. ...and when explaining please explain in "dummie" terms. I think I can tackle anything. My only worries is problems on the actual circuit boards...
Thanks in advance! ...and be gentle
. Gonna see about sending it to Terry. Makes me wonder if the guy who sold it to me had cleaned the heads but not the pinch roller. It was in good shape... not turning to "goo" just had some shed that wouldn't come off.
... It doesn't have a bronze bushing or cartridge at the nose. There is nothing that seems wrong with it. Just wanting to take care of typical maintenance. Your probably right tho.
