importing WAV files into Fostex VF16...need help!
  • Thread starter Thread starter MODROB
M
MODROB
Still using my die-hard VF16 (yep, still going....)
Working fine except, I want to import some WAV files into it, and add to them. Several months back I tried doing this, except I wanted to add just one track to an existing song already on the VF unit. Either way, I'm not having any luck. No matter what I try, I keep getting an error message and the disc kicks out.
I'm using the latest update (yep, ancient too, but it is the latest..haha) and the correct Plextor CD unit, via the SCSI cable.
I have good luck when loading WAV files FROM the VF onto disc, and my computer sees them fine.
Manual says something about discs have to be formatted in FAT16, which I have no clue on how I could do that in this day and time. Even if that is the problem...But again, the normal Memorex CDR discs from Walmart work fine when exporting from the VF.
I've seen a couple of other posts on how some have been able to do it, but there are no details that can get me there. Fostex themselves were no help...basically their answer was similar to what one would say when it was a technology "before their time", and it can't be done. Again, I've have seen posts from users who say they have done it.
So, can anybody give me a clue on how I can get these WAVS into my VF16?
Thanks SO much.
Tim
Hi MODROB, firstly do you have the operating manual? you may have already found your answer but if not here's some things that may help. you do not need a formatted disc for the plextor cd burner. i find that cdrw work best with the plextor (some brands better than others, i don't know why, sony work best on mine) make sure that the WAV file(s) are the only files on the disc and not located in a file but direct to the disc ie music01.WAV music02.WAV and so on. Make sure there are no special characters except those listed by fostex that can be used. I will try and copy the manual details for you.
Loading a WAV file
1. Press the [SETUP] key to enter the Setup mode.
The display shows the screen for selecting the Setup
menu.
2. Use the [JOG] dial to select "Load PGM" and press the
[ENTER/YES] key.
The display shows the screen for selecting the device
from which the data is loaded. "SCSI" flashes.
3. While "SCSI" is flashing, press the [ENTER/YES] key.
The display shows the drive name and "DOS Format",
followed by the screen for selecting the WAV file to be
loaded, showing the WAV file name and size.
If no disk is inserted, "No SCSI Disk!" is shown.
4. Use the [JOG] dial to select the desired WAV file to be
loaded.
If more than one WAV file with different file names (the
first 6 characters) is saved, you can see each file name
(by the first 6 characters) in order when rotating the
[JOG] dial. You can also select "Eject" to remove the
backup disk.
<Note>
The VF-16 cannot recognize any other file names but
"******##.WAV" and cannot load such disks. A WAV file
with an unique name (the first 6 characters) is recognized
as an independent backup file and can be selected.
5. After selecting the desired WAV file, press the [ENTER/
YES] key.
The display shows the screen for selecting a track to be
loaded. "All" flashes initially.
Besides "All", you can select any one of tracks (01
through 24) by rotating the [JOG] dial.
6. After selecting the desired track(s), press the [ENTER/
YES] key.
The display shows the screen for selecting the load
destination program to which a WAV file is loaded.
You can select the program by using the [JOG] dial.
When the screen shows "Title" and "Size", the selected
program will be deleted and replaced with the WAV file
loaded.
When the screen shows "Title" and "New PGM", the WAV
file loaded will create a new program.
<Note>
If the current drive does not have enough available space
for loading the WAV file, the size indication on the screen
shows a negative value ("-***").
In such a case, select a program that can be replaced
with the WAV file loaded without causing the disk space
shortage, or delete unnecessary programs by the "Delete
PGM" menu in the SETUP mode.
7. After selecting the load destination program, press the
[ENTER/YES] key.
When selecting a new program as the load destination
(by selecting an option showing "Title" and "New PGM"),
the load operation immediately starts.
When selecting an existing program as the load
destination (by selecting an option showing "Title" and
"Size"), "Overwrite?" and "Sure?" appear. Pressing the
[ENTER/YES] key will start the load operation.
During the load operation, the screen shows something
like the one as below.
As the data load goes on, the remaining data size shown
on the screen counts down.
When the load operation is completed, "Completed!"
appears on the screen.
<Note>
The title of the program to which the WAV file is loaded
is replaced with the WAV file name loaded (the first 6
characters).
8. Press the [EXIT/NO] key (or the [STOP] key) repeatedly
until exiting the Setup mode.
To go back to the previous step or abort the
operation, you can also use the [EXIT/NO] key or
the [STOP] key.
<< Special loading method when using a computer >>
(*) Method to load specific tracks.
The backup disk in which files are saved will contain files from “******01.WAV” up to “******24.WAV.”
Should these files be deleted, moved from the root directory, for example, into a another folder or the
file name changed which cannot be acknowledged, this recorder will not recognize this file.
When a backup disk changed in this manner is loaded, only WAV files with file names “******##.WAV”
which are located in an acknowledgeable root directory can be loaded.
For example, if the “zero number of data” made at save is deleted from the backup disk and then load
is executed, only WAV files recorded with any other sound can be loaded.
(*) When loading WAV files saved in a multiple number of disks, they can be loaded by a special method
derived from the above method.
Assume that there is backup disc 1 saved with “******01.WAV” through “******12.WAV” and disc 2
saved with “******13.WAV” through “******24.WAV.”
First, when backup disk 1 is loaded, files in tracks 1-12 will be loaded. At this point, tracks 13-24 will not
be loaded and thus be non-recorded. Next, when backup disk 2 is loaded, files in tracks 1-12 remains
intact and tracks 13-24 only will be loaded.
< Note>
WAV files which can be saved/loaded by this recorder must have file names written as “******##.WAV.”
Other file names cannot be acknowledged by this recorder.
Unknown file names will not be acknowledged and could cause malfunction. Extreme care should be taken when
changing file names and making folders on a computer.
* The first six letters will be the title shown in the SETUP mode “Title Edit” display.
* The last two letters “##” represent each track number (1-24) of the WAV file which are to be saved/loaded.
* The last “WAV” is the extension which indicate that this is a WAV file.
* File name of the WAV file which is to be saved in the backup disk of this recorder will all be recorded in capital
letters. However, in certain computers, this WAV file name will be displayed in small letters.
(*) Method in loading by changing the track.
If the two letters “##” in file name “******##.WAV” in the backup disk are changed, it will be possible to
load them on this recorder on a track different from that at the initial save. For example, if a WAV file
named “ABCDEF01.WAV” on track 1 is changed to “ABCDEF03.WAV” this WAV file will be loaded on
track 3.
(*) Method in loading by changing the title.
If the 6 letters “******” in file name “******##.WAV” in the backup disk are changed, it will be possible
to load them on this recorder under a title different from that at the first save. Letters which can be
used at changing the file name in a computer are those only indicated below. All of these letters must
be one byte size.
Alphabets : A-Z and a-z
Numerals : 0-9
Symbols : !#$%&’()@‘_=
******01.WAV ******01.WAV
Backup Disk 1
Backup Disk 1
Hope this helps. Mail me at mark.cawston@live.co.uk If you need more help, however I'm not an expert but will do my best.
Cheers
Mark
