Impedance Matching Help!
  • Thread starter Thread starter josiah7
J
josiah7
Could someone please give me a newbie a little advise?
I have several audio devices I want to chain together. I have read where the output (source) impedence should always be ~10 times lower than the input of the next device. I am still not sure if I need to use impedance match transformers somewhere or if I am ok.
Here are the impedances of each device in the chain I want to create, the values in "(, )", are input and output impedances of the devices;
1k --> (22k, 100) --> (1M, 600) --> (22k, 100) --> 2.2M
Will this work ok or should I use some impedance match transformers like is commonly used for a microphone? What sizes?
Thanks for any help or advise, I appreciate it!
Someone can correct me if I am wrong, I always thought you needed to MATCH impedances?
You should post the units that are in that chain as well.
:cool:
:cool:
Sorry, I should have been more clear. All units are in Ohms;
device #1 (1000 ohms output) into -->
device #2 (22,000 ohms input, 100 ohms output) into -->
device #3 (1MegaOhm input, 600 ohms output) into -->
device #4 (22,000 ohms input, 100 ohms output) into -->
device #5 (2.2 MegaOhms input)
Anyone?
I'm not sure about the ohmage.... but I can tell you a more confident answer if you name the units say like a rode tube microphone into a golden age preamp into a RNC compressor into a analog/digital converter....
You know what I mean ?
:cool:
