Imagine you have $2k and some gear, what to buy next??
  • Thread starter Thread starter alvilla
A
alvilla
Hey everyone, I ran into some cash and really want to build something to start recording.
This is what I have right now:
- a couple of decent PC's for hard drive recording
- ntrack studio for multitrack recording (WAV)
- nice electric guitar
- decent electronic drums (simmons, not great but ok)
- electric bass
- a bunch of acoustic guitars
Now, this is what I'd like to have:
- a way to record my instruments
- a way to record vocals
- a way to mix and do all that processing
- probably a keyboard/synth if it's within budget (I do play keyboards so I could actually use it)
So the question is if you were in my place and had between 2 and 3k to spend, what would you get?
I've read advice on getting the shure mics and some USB-based recording devices but I could use advice from actual users if possible.
Any help is appreciated!
A.
First I would go for a decent mic. Lots of choices. I really like the AKG 414 --good used ones go for for about $500
Then an interface. I have the Lexicon Omega, and it works fine. It comes with Cubase LE so you would have recording/mixing software as well.--$200
A channel strip is handy. I have a dbx which has compression, gate, deessing and hi and low freq. enhancers-- they are under $200. You could also get a higher end one with the amount of cash you have available.
Accurate monitors--lots of choices--I use 3-way home stereo speakers that I have learned to mix on, but also play test mixes on good headphones, boomboxes, car stereos, etc. to see if they translate well.
Hope this helps!
DJ
I forgot a keyboard! I got a great used Yamaha 88 key w/hammer action for $400.
- electric bass
A.
A ShinyBox ribbon mic, either a M-Audio Luna II or a Studio Projects C1 large condenser, a couple of Naiant X-W small condensers, a M-Audio DMP-3 preamp, and the best damn monitors I could find with what was left over.
You didn't mention your I/O so I assume you're good to go there. If not consider the M-Audio 1010LT.
