JCH
El Nacho
I hadn't done anything with the body since I cut it out last week, so it was still pretty rough. Today I contoured the front and back similar to a strat. I want it to be light and comfortable to play. I had run the body blank through the surface planer, so the front and back were smooth, and flat. I sanded it all, and then made a radius cut on the edges. I shot a good coat of primer on it to seal things, and glued in the neck.
This is a sleeper block I put in the neck pocket so that I could run the router with the radius bit around the body front, and back. It's to guide the roller bearing on the bit, and to keep from splitting the wood.
I streamlined the neck joint. It's taking shape.
All glued up
All glued up
