K
kkamikazekidd
Well, let me tell you my set-up. I play mostly an acoustic guitar that I line in to my pc. I figured out quickly that I needed a pre-amp, so I hooked up the old trusty Tascam 106. It works fabulous. to my amazement , better than live. My problem now is that when I use my mic thru this simple system I get hiss. My vocals are bad enough without it, my question is can I get rid of this hot mic problem with a vst plug in or should I just plug right into the mic in on the pc? I would like to keep everything plugged into the Tascam so I can just push some buttons the old fashioned way. Even when I turn down the levels I still get the hot mic thru the tascam, its just softer. When I line in the mic directly it seems ok, but not very loud, and I'd hate to keep switching wires around.
