Hi there
I can't compare the 166XL to
a 160A as I have neither. However, I do have a 160X, a 166 (not XL) and a pair of RNCs. Therefore, I can offer a synopsis of what these units are like.
I have to agree that the 160A/X/XT comps kick some severe butt on most things. My 166 is pretty sweet too but not to be confused with the newer 166XLs. I think my 166 (also discontinued along with the 160X/XTs) is pretty much supposed to be a dual mono/stereo version of a 160X/XT. However, it contains a different VCA from the 160A/X/XT units, so bang goes that theory.
My 160X is great on bass and drums (especially kick) whereas the RNC is harder to dial in good sounds for bass. The RNC is superb for vocals and is very transparent. You should get both.
You won't be disappointed with a 160A/X/XT. Either will do the business as they each have the same input circuit and same VCA. They are very similar and aren't replacements in succession. As I understand, there were several slight modifications done over time which the law required a new model number for. Therefore, don't be too worried about one being better/worse than another. They may have minimal sonic differences but according to dbx, this should be virtually indistinguishable.
On researching and regarding differences between the X and XT, the older 160X has an LF351 op-amp with slow output transistors which many say inpart a cloudy sound. The XT has an identical circuit to that of the X for the unbalanced output.
The XT's balanced output uses two 5534 op-amps without the slow transistors. This is said to create the sonic difference between the two units. Many folks have commented on the sonic difference on these outputs saying that the options with XT are that you can have a cleaner, faster output, or a vintage cloudy unbalanced output.
Another difference is that the 160XT had a hand stuffed PCB whereas the newer 160A is a machine stuffed surface mount.
Apparently, the 160X has the option of adding a transformer whereas the others do not.
I think you really need someone who owns a 160A/X/XT and
a 166XL to chime in and give an opinion to inform you better.
Regards
LiD
