Reggie
PutsTheLotionOnItsSkin
30db of boost?
If you make a graph where amplitude is the Y abd time is the X. Make the Y a logrythmic scale representing the possible voltages. (the positive side should be enough to prove the point) Now, superimpose an audio signal on top of it.
I call it "Cool Edit."
Not real sure what you are getting at here, but let me ask this: Below -60db, is +/-34 different possible levels enough to accommodate any possible analog waveform 0-22000Hz (-90db floor)? I hope your waveform happens to be in sync with the converter so that the wave just happens to be at one of the possible voltage levels at the exact moment it is getting sampled. Otherwise there will some rounding going on, getting more severe the lower in level. I always knew there was a % of quantizing error, but I guess I just never really knew where it came from or how it worked.
Another interesting fact on what those lower bit values actually are:
Value #0 = -96db
Value #1 = -90.3db
Value #2 = -84.28db
Value #3 = -80.76db
Value #4 = -78.26db
Weird, huh?
This book looks interesting in a nerdy way: http://books.google.com/books?id=VZ...H2ov&sig=3hPQQp7WZsdeKCWr5aw1TygrFXk#PPA37,M1
Check out pages 37-38, seriously. Seems to kind of say what I've been clumsily getting at.
), but I really have gotten only incrementally closer to an understanding of the Nyquist part of it and the whole amplitude with two samples question.
