C
		CanopuS
Amateur music since 1847
How can you check to see what effects you have put on a certain track. Ta
Can't you just double-click the effect in the track to see its settings? (Maybe you're using a pre-HS/SONAR product, in which case I don't know squat - know very little squat in HS/SONAR actually - LOLCanopuS said:Nope not destructively, merely I'm not sure whether or not I used the same effects for one bit as I did for the rest, but I want it to sound almost exactly the same, but its too hard to tell![]()
 moskus said:And if you're wondering about Real-time effects and why you can't see the preset-name in the drop-down box after you've closed the plugin and opened it agan, I can tell you that that's a DirectX issue and needs to be solved by Microsoft (meaning it will not happen...)
They where the ones that told me...vicevursa said:I'm just curious, has the above been confirmed by cakewalk's people?
I have never thought of it as a missing feature. And since it's nothing Sonic Foundry, Cakewalk, etc. can't do about it (except complain to Microsoft), then I would defininentaly sell my product "crippled" (especially since it's not my fault).vicevursa said:Doesn't that seem a bit odd? Sonic Foundry and Twelve Tones (probably others) are admittingly releasing a product that is "crippled
I strongly believe plug-in developers and application developers are doing it the right way, but that's probably your point...Strryder said:IF the software companies are following MS's instructions on how to make DX effects, they would not be responsible for the problem.. right
