I think this whole concept is getting out of hand. I believe this is because misconception of principles and coeffecients. On page 164 of Alton Everest's Handbook of Acoustics, it states
"........Low -frequency absorption can also be improved by spacing the absorbent out from the wall. This is an inexpensive way to get improved performance--WITHIN LIMITS.....Spacing 1"material out 3" makes its absorption approach that of the 2"material mounted directly on the wall....."
Yea, but at what frequency. Related to GUITAR, here is the real deal.
http://www.bobgolds.com/AbsorptionCoefficients.htm
Product thickness mounting density 125hz 250hz 500hz 1000hz 2000hz 4000hz NRC
703, plain 1" (25mm) on wall 3.0 pcf 0.11 0.28 0.68 0.90 0.93 0.96 0.70
703, plain 1" (25mm) 16" air 3.0 pcf 0.65 0.94 0.76 0.98 1.00 1.14 0.90
703, plain 4" (102mm) on wall 3.0 pcf 0.84 1.24 1.24 1.08 1.00 0.97 1.15
703, plain 4" (102mm) 16" air 3.0 pcf 0.65 1.01 1.20 1.14 1.10 1.1 1.10
This tells me that at 500 hz, 1" 703 that is spaced out from the wall 16" improves its absorption coeffecient by a WHOPPING 1/100 of a percent. BIG FUCKING DEAL Do you think you could hear it?
Here is a portion of Eric Desarts chart found on this thread(Excuse me Eric, but at least I gave the link.)
http://johnlsayers.com/phpBB2/viewtopic.php?t=2429
ABSORPTION VALUES VERSUS MATERIAL THICKNESS AS % OF WAVELENGTH.
Compare column 3 , giving the material thickness as a % of the wavelength, with the corresponding absorption in Column 2.
You can compare them with the Engineering rules given before.
It's clear that the traditional 1/4 wavelenght (25%) approach does NOT apply.
This approach only relates to PLAIN waves at STRAIGHT incidence for DISCRETE frequencies:
OC 703 · 1.0" · 25.4 mm
0125 Hz · 0.11 · 000.9% ( This is less than 1/10 of 1 percent absorption, Rick Fitzpatrick )
0250 Hz · 0.28 · 001.8%
0500 Hz · 0.68 · 003.7%
1000 Hz · 0.90 · 007.4%
2000 Hz · 0.93 · 014.8%
4000 Hz · 0.96 · 029.6%
OC 703 · 2.0" · 50.8 mm
0125 Hz · 0.22 · 001.8% (Still less than 2 percent-Rick Fitzpatrick)
0250 Hz · 0.82 · 003.7%
0500 Hz · 1.21 · 007.4%
1000 Hz · 1.10 · 014.8%
2000 Hz · 1.02 · 029.6%
4000 Hz · 1.05 · 059.2%
OC 703 · 3.0" · 76.2 mm
0125 Hz · 0.53 · 002.8% (Less than 3 percent-Rick Fitzpatrick)
0250 Hz · 1.19 · 005.5%
0500 Hz · 1.21 · 011.1%
1000 Hz · 1.08 · 022.2%
2000 Hz · 1.01 · 044.4%
4000 Hz · 1.04 · 088.8%
OC 703 · 4.0" · 101.6 mm
0125 Hz · 0.84 · 003.7% (less than 4 percent-)
0250 Hz · 1.24 · 007.4% less than 8 percent..
0500 Hz · 1.24 · 014.8% less than 15 percent -Rick Fitzpatrick)
1000 Hz · 1.08 · 029.6%
2000 Hz · 1.00 · 059.2%
4000 Hz · 0.97 · 118.4%
Considering, ON GUITAR, from the Low open E string to an "A" note at the 5th fret,on the high E string, which is 440hz, that is about 80 percent of the available octaves and notes on a guitar fretboard. That tells me, that 80 percent of the guitar fretboard is BELOW 500 hz.. Soooooooooo......Even Eric Desart is telling me that 4" 703, absorbs less than 14 percent of 1 Sabine for every square foot of 703 @ 500 hz, and drops off like a stalled Cessna as the frequency gets lower, so you tell me.
fitZ
