T
Terry Wetzel
Is there anyone out there who can help me out by explaining decibles as applied to final mastered cd level.
I'm not new at this and I understand that db can referr to a voltage, a ratio of comparison or as an rms or peak level. I use the Ml9600,Masterlink deck for finishing my recordings. What is the proper method for obtaining a finished master recording with a level of the recomended
0db,(or as close as possible without clipping). It seems that after using the eq, limiting and normalize options of the Maqsterlink, I always wind up with from +3 to +7db and sometimes even higher. Which levels should I be concerned with for the final mix before mastering. My mixer has both analog and digital levels in the output section.
