hello. i have an oktava mkl-2500 without a power supply. does anyone know where i can get one? (i also have a mxl v69me...is its power supply compatible? i doubt it, eh?)
Most likely both mics use the same voltages, but connectors have different pinouts. There are three ways to do it. 1) To change internal connection in your Octava or 2) To drill another hole for additional XLR 7 pin in your PSU to work with Octava 3) to make an adapter for Octava, which will reroute pin assignment. Your Octava might need some tweaking if the voltages are little different.
Without schematics or seeing the mics and PSU, it is hard to say exactly what to do, though.
Yes, I remember Stewart posting it. The problem is that, IIRC, there were a few versions of MKL2500. The one on the schematics is a cathode follower. There also was one as an anode follower. I didn"t see its schematics, but it might have different capsule bias arrangement, pinout, and B+ voltage.
The filament is way underheated. The 6Z1P is a 6.3V filament tube, so you can use usual 6V, most Chinese tube mics PSU deliver.
Hey Jon, try to draw a schematic of your mic if you can or take some *detailed* digital photographs and notes of the innards and we could maybe draw one for you. This kind of info is usually hard to come by and could be very helpful for others
