I can't figure this out!
  • Thread starter Thread starter InspektaBrain
I
InspektaBrain
OK....so i got the pc side of things handled...at least i think so. I got all the software i need and have made a few tracks using only my computer a sequencer (fruity loops) and a cheap $30 mic to record vocals.
So i want a new direction. I'd really like to get better vocals recorded and i'm a Bass player so i want to be able to add that in too. Of course being able to add drum machines, samplers, and assorted other components into the mix would be great.
My biggest question right now is; Should i use the bass amp i have (Rogue RB-120BT) for studio speakers (and will it even have stereo sound) or should i start shopping for a pair of studio speakers. I've thought about possibly trying to use the home theater system i have (Sony Reciever/Amp with 2 tower Sound Dynamics Speakers) but i'm not entirely sure i'd be able to use them in the mix at all.
I am currently lookin' to buy a soundcard or audio interface and a mixer. And i'm very obviously gonna upgrade my mic, but i'd gladly take suggestions on these things as well.
Of course my budget is almost non-exsistent so i need to keep that in mind, but i do plan on recording everything on my computer. So far that's about the only thing i won't have to worry about upgrading for years (and it's my other love so i'm sure my dual processor P4 system will work well for me).
Thanks in advance!!!
InspektaBrain
A bass amp isn't going to come anywhere close to cutting it - it's unlikely to give you a good representation of the high end of the frequency spectrum. And no, since it has only one speaker, its mono. Amps are pretty much always mono. Stereo requires two speakers, spaced out appropriately. You're ultimate goal is a pair of studio monitors. Read this:
http://www.tweakheadz.com/studio_monitors.htm
You're home theatre system, on the other hand, is probably "good enough for now." Standard computer speakers will also work in a pinch.
You really should read through all subjects of The Guide at the link above - it'll give you a good, basic understanding of all aspects of home recording, including deciding what kind of audio interface you need.
The fundamental question there, though, is how simultaneous inputs will you need at one time? And, if your setup is simple, you probably don't need a mixer. Like I said, read The Guide, and then come back with any questions you still have.
InspektaBrain
Since as with most things, budget dictates choices. That being said, I’d recommend spending your initial budget on a good set of near fields (buy once). Good monitors will pay for themselves and yield you the biggest dividends especially in the near (no pun intended) term. Then as you continue saving to support this addiction (and it is an addiction :D ) you can start looking at other equipment.
Monitors have been discussed at great lengths on this forum. Use the search engine and you should have no problem finding information on just about every monitor under the sun.
If you're low on cash even the Alesis Monitor One's (about 200 bucks used for the pair) will **CRUSH** a bass amp.
Trust me--if you are recording NO piece of gear is as important as your monitors. They are your eyes and ears, they are the ONLY way that you can make decisions about the audio--what's good, what's bad, and so on.
Probably the most important piece of gear you can have.
Because, the way it works is that if you are hearing an exaggerated bass your mix will end up without any low end, if the speakers de-emphasize your high end your mix will end up with way too much treble.
You want as accurate and flat speakers that you can afford... period. And no, headphones DON'T cut it.
yea...i have actually learned the hard way about headphones....so i guess i'll just have to keep researching the studio monitors....thanks for the help guys. You've answered my questions almost exactly like i needed!!!!
InspektaBrain
D
Replies
3
Views
344
Eric V
Eric V
Z
Replies
4
Views
721
DrewPeterson7
DrewPeterson7
J
Replies
9
Views
884
TalismanRich
TalismanRich
Wabatuckian
Replies
9
Views
830
Wabatuckian
Wabatuckian
