T
Tillamook
I'm still having a problem with looping when I have a DXi synth track running. It will loop fine on the first run-through, but when I stop the song and then start again, I get a dropout at the end of the loop. I posted about this a month ago, and none of the suggestions (latency, buffers, pci sharing etc....) have worked.
If I archive the synth track (not the track that I've recorded to, but the one that takes the output of the synth and sends it to analog outs) the problem goes away.
The problem exists with all three dxi synths (edirol, dreamstation, dyad).
Cakewalk support says, yeah, there's a problem with that.
I'm wondering if I should get Sonar, but $400 is a lot to throw at this problem, considering HS has all the functionality I need, otherwise. Another option would be to get Fruityloops, and use it as a plug-in, but I'm wondering how seamless that process would be. Would FL act pretty much like it was part of Cakewalk, or would I be jumping through hoops when going from working with midi in FL and audio in HS?????
Is there a chance that Sonar has this same problem?
Any suggestions or opinions?
Bill
XP
HS2004xl
Biostar M7NCD
1000 megs ram
athlon xp 1800+
wd 7200
maxtor 7200 8mb for audio
m-audio 24/96
Bill
XP
HS2004xl
Biostar M7NCD
1000 megs ram
athlon xp 1800+
wd 7200
m-audio 24/96
