Se7en-Costanza
Hey Guys,
I was just after some advice to how i would go about plugging my 24 channel Soundcraft LX7 Analogue Mixer into my Mac to multitrack record on my DAW (of preference) which is Ableton Live. (I'm sure this works fairly the same as Pro Tools, Cubase, Logic or any other DAW, I just personally prefer Ableton for It's layout and my years of experience using it).
So what i want to be able to do is use 16 of my channels on my Soundcraft mixer as direct channels to Ableton, which i can track and mix with using the faders and EQ on the Mixer.
I own two audio interfaces which I think I'll need to do this, a Focusrite Saffire Pro 40, and an M-Audio Ultra8R, which are both 8 Channel interfaces.
I have in the past dualed both of these interfaces together so I could record drums with 15 mic's (a little extreme i know, but it was a bit of an experiment). How I've always recorded is directly plugging microphones into my audio interfaces as they record onto Ableton. Now i own a Soundcraft mixer I would like to be recording using this, as I like their preamps and on board EQ, but i would also like to route the channels on Ableton back into the mixer so i can monitor and mix with the desk's EQ, faders and auxiliary controls, as well as the outboard gear i have connected to my mixer. Is it possible?...
The soundcraft mixer has 24 inputs in total, and direct outputs on 16 of the channels, as well as inserts on all channels, if that helps with figuring out how to go about doing this.
Thanks guys, hope you can help!
