How to Use 2 laylas 20 bits with Cubase 6
  • Thread starter Thread starter moyotte
M
moyotte
I'm having problems to connect my 2 laylas 20 bits with cubase 6 using the clock sync, I hook up one of my
layla-1 clock out to the clock in of the second layla-2 then I select the ASIO ECHO WDM driver form the device set up in Cubase 6 and finally I go to Devices, Vst connections and tried to Select my 20 in and out puts of my two laylas, suddenly when I activate the in or outs of my layla-2 there is no more sound on my cubase, I can only use my ins and outs of my layla-1. I want to use all my outs from layla-1 and layla-2 at the same time because I have a mackie 24x8 mixer.
I already check both laylas separately and they are both working perfectly. One more thing I already select the my Layla-1 as the master internal Out Super Clock and my Layla-2 as my Slave In Super clock from the echo console version 6.11 beta.
Any help will be very appreciated?
Have you tried to change the PCI slots your cards are in? What other PCI cards are you using? I had a problem similar to this I had to move both Laylas to the top two PCI slots. I have also experienced this problem due to a second PCI graphics card . If you can try and remove all your PCI cards and put the two Laylas in the top two slots and see if that fixes the problem. It sounds like your PCI routing may be having IRQ conflicts
