P
Peter Jules
Hi.
When working with multiple takes in one track I can see all takes besides each other and I can also select which of these takes is the active one. But when I look at them later how can I actually see which one of the takes is currently the active take? How can you tell from the image below which one of them will actually be played back? I'm even afraid to touch them because once I click any of them I will change the active take and I may lose the good one.
The only workaround that I'm using is: Highlight all takes in track, right-click, item and take colors, click on "Set all takes of selected items to default color". And then in the next step select all active items, right-click, item and take colors, click on "Select active takes to custom color". But this gets all messed up again as soon as I change something, e.g. do a split or record a new take.
I would really like to have Reaper highlight all active takes in one color and all inactive takes in a different color automatically but I haven't found a sensible ways to do it. Does anyone have a good suggestion?
Thanks,
Peter
Thanks,
Peter
