monty
Banned
I delete tracks and most all the original recording and re-save as a bun file and the file size remains the same…what’s with that?
Thanks. That reduced the file size considerably. I had 2 tracks and bounced each one individually...back to it's original location by default I guess. Loads much faster now...thanks.Qwerty said:Bounce any slip-editted clips back to a track otherwise they will be referencing a whole bunch of different versions of the same take for each slip-edit.
Q.
Actually you don't need to bounce the tracks. Just use the Apply Trim command.Qwerty said:Bounce any slip-editted clips back to a track otherwise they will be referencing a whole bunch of different versions of the same take for each slip-edit.
Q.
Qwerty said:Cool - thanks for that! I always thought that also applied the gain staging, though....
Q.
Yup, that works too. So which is the best way?dachay2tnr said:Actually you don't need to bounce the tracks. Just use the Apply Trim command.
Nope, that doesn't do it.mixsit said:Do a 'Clean Audio Folder'.
Q.Hmm. I thought it cleared all the old (unused) takes.monty said:Nope, that doesn't do it.
mixsit said:...maybe it was just my audio folder once it got to large for a 'bun burn.
Wayne
