Yes, it's very different. It's not like a delay at all. You get phase cancellation when you copy/paste/shift/pan. Instead of questioning our manhood, you should question your ears.
			I'm with Greg L.  No idea why people lazy out with that.  It always sounds like phasey garbage to me.  The HAAS effect sucks.  Just track it twice.
OK, rather than get into a pissing contest, here it what I am trying to get across, and if you want to experiment and find out for yourself if you like it, great. If you would rather not, also great. But my Kung Fu is taking a rest.
#1. I question no one's manhood. I said no one should worry about anyone else questioning their manhood if they like to copy/paste/shift. If that's what makes your music sound good to your ears, have at it.
#2. By using an online calculator like so;
Phase angle calculation from time delay and frequency calculate phase lag difference time of arrival ITD phi phase shift - sengpielaudio you can 'see' that 20mS and 1KHz has a whopping 7 degrees of phase shift. Whoopie. It takes 25KHz to get 180 degrees. 500Hz has an inaudible 3.6 degree phase shift. And single repeat delay is no different than copy/paste/shift.
#3. If the Haas Effect bothers you, go much less than 25mS, or where most research tells us it begins to make a difference.
#4. The best way to learn is to try it. You can't learn to swim by reading a book. Do.
#5. Rather than elaborate excuses of why it can't be good for the whole planet because
you don't care for it, a simple 'whatever floats your boat' is the preferred answer. Always take the high road.
Remember, we're all just amateurs making bedroom recordings of mediocre music that no record company is going to kill for. Nothing to compete with Dark Side Of The Moon in sales and Top 100 longevity. This isn't rocket surgery. So just having fun, and making new sounds that are created by taking chances, and not making excuses of why it can't be
this way or
that way is all you can do. And I believe most, if not all, of any post I make always stresses that what works
for you is 'right'.
Good night, and good luck.
