evm1024
(Chalk this up to a brain fart if you want to)
I was daydreaming on the way to work this morning and was thinking on how to make a speed calibration tape.
The problem is that no matter what the speed of your deck if you record a 1KHz tone you will get that back. One needs to know the frequency recorded for the tape to be useful.
Many digital counters have a count pulse mode where the total number of pulses are counted. Perhaps some of the software counter have this. This gives us an absolute value that does not depend on some time calibration in a counter and can be used to our advantage. So....
At 15 ips 25' of tape will pass under the heads in 20 seconds. And a 1KHz signal will put 20 k cycles on that same 25'.
SO if we measure out 25' of tape and cut it as close to exactly 25' as we can get, then put leader tape on it (enough so that the deck speed will stabilize) and then record a (close to) 1KHz tone we will have a speed standard. How so?
Set up the counter in total count mode and then play the 25' tape. It will start counting pulses and total them for you. If the tape has 20,000 pulses then you have a 1 KHz tone on it. (20,000/20) If the tape has 21,500 you have a 1.075 KHz tone (21500/20) etc.
With a known signal on tape you can use an accurate frequency counter to adjust the transports speed.
The count of pulses is most accurate measurement that you have in this process. Getting 25' of tape is a little harder. 1/8" off and you have 125 pulses error which gives 0.625 % error.
Errors in the freq counter are a bit harder to quantify. The poor mans way to calibrate a counter is to get a radio that is capable of receiving WWV (the time standard) and setting an oscillator to beat against its carrier (listening to WWV at 10 MHz and setting your oscillator to match means that your osc is at 10 MHZ) Then adjust your counters master oscillator to have the counter read 10.00000 MHz. Or some such....
Of course once you have adjusted your deck to be 15 ips you can set a 1 KHz tone on it and measure 20,000 pulses for a better reference tape.
Like I said, Just day dreaming. I may have to try this out sooner or later.
Regards, Ethan
Regards, Ethan
