			monkie
The strings on my strat is kinda of high which can be pretty tough to bend, can anyone show me how to lower it?
Thanks in advance for any help.
			If you have the usual strat-style bridge, each string is sitting on a little saddle by itself (these things). Each of those saddles should have two little screws, one on either side of the string, that adjust the height.
			You're correct -- it's the 12 tiny ones. The other ones are to adjust the intonation. What tool you use depends on what they look like on top; I'd suspect you need either a little screwdriver or an allen wrench. They may move easier if you temporarily tune down to get the tension off the strings.
			Well, the strings are closer to the pickups now so it may be wise to drop them a little to compensate.
And yes, usually lowering the strings has effect on the intonation. Best way to intonate is to use a very accurate tuner, tune open and then at the 12th fret. If it's flat at the 12th, you need to shorten the string (move saddle closer to the nut) --if it's sharp, vice versa.
Why would lowering the strings affect intonation? The saddle to nut distance remains the same when you raise or lower the string saddles on a Strat.
It has to do with string tension, string deflection, and the nature of the temperament but you will often have to intonate after making action adjustments. More so on a light set of electric strings with an unwound third.
			Interesting. Why would there be a change in string tension, if that is what you are saying?
