hailtotheking
I want to clean up some timing issues in a multitrack drum recording done with 4 mics (kick, snare, overhead, and hi-hat). It seems that this is an impossible task, though there seem to be tools out there that look like they're designed to help (i.e. time stretch/compress tools). Can I get some pro advice?
The big problem for me with adjusting the timing of off-beat drum hits is dealing with microphone bleed. For instance, if I have an early kick hit and I edit the kick track to fix the timing, I still hear the early kick hit coming from the other mic tracks. I imagine that this timing effect will be even more noticable after adjusting mic levels during mixing or if I had originally recorded with room mics far away from the kit (15 ft). I want to avoid these timing problems and it seems to me that the best way to edit this is to adjust the timing in all mic tracks so all kick hits are moved up in time by the same amount. Anyone know of a way to do this so that I'm editing the kick at the right start and end points in each track and so I'm not screwing up the timing of the other instruments (snare, hi-hat, crash, toms, etc.)?
I've looked into a ton of other possible solutions and it seems like re-recording and punching in over the off-beat sections is really the best way to completely solve the problem but.. is this really the only recourse? All these stretching tools I've been reading about seem to promise a fix to timing problems long after a take is recorded, but maybe they're intended to work only when no bleed is present.. I dunno . I really want a way to fix the recording I have without re-recording since I'm pretty far away from the studio and may not be able to get another performance from the drummer. I'd love to hear some ideas on how I can really solve these drum timing issues with mic bleed. Thanks a lot.
