T
The Ghost of FM
Banned
Sadly, I think it is a defective unit.fellwinter said:Hi, I am starting to think it might be a bad unit too.![]()
How you described the dbx channel lights coming on for no longer then 10 seconds indicated problems. Probably on a component level on a board inside the unit.
Did you purchase this used off of a stranger? Did they give you any indication that there was a problem with it or did they pull the old, "I'm selling this for a buddy and don't know shit". routine?
Besides anything else, I don't believe the DX-D4 was designed to interface with the 3440. The control signal connectors are different, no?
Do you have the manual for the 3440? If so, which dbx NR unit does it specify as the correct one to mate with it?
Sorry for all the headaches.
Cheers!
