G
gnarled
Re: *raises hand*
Well, I think with the john sayers approach he's talking more about spaced pairs, not coincident pairs. With spaced pairs (refering to your picture) you might put one overhead over the drummer's left shoulder and the other one in front of the kit on the side with the crash and high rack tom. That way, both mics will get the snare at approximately the same level so it will be centered when panned and (if you measure the distance to the snare) the snare will be in phase.
Ben
Kelly Holdridge said:Ok, I've been going off of John Sayers' approach to drum micing, which includes putting the snare in the middle of the stereo overheads by offsetting the axis of the stereo spread. Here's a picture of what I understand John to be talking about:
Ok. What I'm wondering is why worry about phase cancellation with precise measurements if you can get the diaphragms close enough together in an X-Y config? Is it because of the middle tom (or whatever sits below this offcentered axis) being louder than anything else? Is there a distinct problem with this setup? (the snare and hi-hat both have the same off-axis position to the 57's)
Ben
). In keeping with the mics being equa-distance from the snare, the left mic gets pulled back a bit which also helps.
