Chris Shaeffer
Peavey ROCKS!!!!!!!!!!!!!
Hot Damn!
OK, I may not have it exactly right, but it sure is fun! Here's what I did:
GT 5sm in figure 8 into Art MP Channel 1
1/4" out to Track 1 in Cubase
XLR out to Art MP Channel 2 with phase reversed
1/4" out to Track 2 in Cubase
C1 in the center into Track 3 in Cubase
Set levels on the MP so that they are identical (which was quite a game), set levels equally into the computer...test in mono- yup the sides pretty much disappear.
Play some Tom Petty-ish stuff from the center position. (Feel like an idiot...) Sounded like doo doo in the cans.
Back in Cubase, panned 1 & 2 hard left and right. Left 3 dead center. Left all levels where they were- roughly equal. Pressed play...
WHOA!!!!! That's some W___I____D____E stereo! And loud as heck. OK, hit the mono switch to see what it does....
Drops about 12dB. Is it supposed to do that?
Hmmm...reread Harvey's post several times.
I fiddled with the levels and found that if I keep the side channels lower (about -15dB) I can still get a nice full stereo image that isn't too affected when I sum to mono (and doesn't sound too much like my...ah..."studio" room). I'm not entirely sure what's going on, or even whether I have it right or wrong...
When I mute the center and have the sides panned out I get a really yucky, quiet, thin stereo. I was expecting it to cancel out alomst completely. If I then hit the mono switch it *almost* disappears- there is only a tiny bit left- proabably the inconsistencies in the two signal chains. The meters say it peaks at -22dB but I can hardly hear it.
When I bring the center back the stereo effect is much more noticeable than the tinny sides by themselves so I think its working the way it should, but I don't really have perfect mono compatibility because of my half-arsed signal chaining rig.
I wonder if:
- The figure 8 pattern on the GT isn't tight enough.
- My funky signal chain is causing this volume change in mono.
- It would work better recording more than one instrument.
- I somehow got it perfect and this is normal. (Not likely....)
Yehaw! Another fun evening courtesy of Harvey Gerst. Someday I might even understand some of what I'm doing.
Chris
I wonder if:
Chris
