long but detailed
Tight Thread !!
I come in the studio and power everything up. LOL
(This is based offa when I have no clue about what ima bout to do)
I load up Sonar and Surreal or Reason
I think in my mind of a tempo that I might want
I go to Sonar and loop 8 bars based on the tempo. ( vibe/think)
Stop Sonar and go to my sample bank via wavelab
Set Wavelab to "Auto" and click on the samples for playback
Once I feel a sample I then load it into Surreal
go back to Sonar and pick the surreal bank with that sample
Start the loop back up with Sonar and puch the keyboard controlling the sample.
Move up and down the keyboard with the sample until I find the pitch,speed, etc I want to use that works with the tempo
Once found,,, press record on Sonar and play 8 bars of the sample variations
Once the sample is recordeded I check the timing. Quantize sometimes,, somestimes I dont need to
Then I pick another port/bank in sonar for different Drum sounds using softsyths or external gear. ( Still all Midi though)
Kick first
Snare
Hi Hat
and whatever drum sounds that may compliment the loop
Then I pick the softsynths for instuments.
For Basslines (Depending on the track ) I may pull my real bass out or go with a softsyth bassline
I then build the track by cutting and pasting what Ive done so far up to 4 min. Some parts stay,, some dont
Lyrics ?
Vox are tracked into Sonar on seperate tracks.
1 main Vox for each flo'er, 1 Adlib, then 1 fillin
When through with tracking I then go into Sonar and pan,level,reverb,chorus the softsyths and send them all out to a digital console via Spdif ( Stereo)
Then I send each Vox track to a seperate channel on the Digital console and tweek them in the console
I level everything in the console, then comp,EQ,effects, still in the console.
Next I get a fresh set of ears to critique it all.
If it passes,,, I send the whole mix through a stero buss of the console back into Wavelab at 24/44.1. I used to used 24/48 but the resampling was pretty weak to me.
once the final mixdown is in Wavelab, I flatten all settings (for the stereo wavefile channels) on the console and send them back through from wavelab while I master it in Wavelab.
On the final mixdown I stay below 0db for every channel
Burn it and ride out.
That's what yall talkin about ?
Malcolm
