Let's say you have a 4 track tape recorder.
1. Record the drums on tracks 1, 2, 3. Play tracks 1, 2 & 3 back, recording them on track 4 while recording the bass at the same time. Listen to track 4 and if it sounds good then proceed. If not do a retake.
2. Next record the guitars on track 1 and 2. Listen to them and edit if needed. Play tracks 1 & 2 back, recording them on track 3 while recording another instrument like a harmonica, keyboards or a flute. Make sure you don't record over track 4 while you do this. Listen to tracks 3 and 4 and if they sound good then proceed. If not redo track 3. You should now have a mix of guitars+ on track 3 and drums and bass on track 4.
3. Record another instrument or a vocal on track 1. Listen to it and edit if needed. Play it back recording on track 2 while recording another instrument or vocal at the same time. Again listen, fix and or proceed.
4. Finally record track one with whatever instrument or vocal you have left, listen and edit. You can now mix the four tracks down to stereo for mastering.
This isn't an easy way to do recordings but if you monitor the volumes, pan, and use an equalizer properly to notch out ranges for different instruments you can produce a decent recording of 10 instruments onto a 4 track. You can use a limiter while recording but I'd save the compression for mastering. Of course you don't need to track the instruments as above. You can make your own arrangement of goatshead soup. G/L and have fun
