Erockrazor
I mix in (2x) real-time
They just seem to have that "fuzziness" or "Buzziness" that is associated with recording distorted guitars line-in. Take a distortion pedal, plug it into your mixer instead of an amp, and you'll hear what I'm talking about. I agree with, smart people+ good equipment+ good players= quality sounding recordings. In this case, it sounds line-in to me. Like I said, I could be wrong about this recording.
Ditto this. Definitely sounds direct at least for a little of the guitar tones. I'm going to go ahead and say it was re-amped. Some of the guitar tone sounds direct and some sounds more amplike to me.
I'm listening to this in headphones and it's pretty disgusting how bad this whole mix sounds for this band. So compressed. The cymbals are just sizzling and the vocals sound limited. The loud parts make me sick. I'm not even talkign about the music. Too bad this is probably all at the expense to make it loud as hell.
Like was said earlier, read this article. http://www.badmuckingfastard.com/sound/slipperman.html#contents
Then read it 2 more times and really think about it.
Record with the best gear you can. Get it sounding sweet before it's in your DAW. Don't ignore microphone placement. Don't discount DI and re-amping as bad alternatives. If used well, you can use so much to your advantage.
multi-track guitars, listen to whats happening in the mix. Reverb and compression can work great when you listen to them. Figure out what needs to be done to make your things sound better before it's in the box. Then the end result will come easier.
All things said, I wouldn't consider the songs you suggested, a big sound.
Good luck, Eric
