How do I sync a 388 to Sonar?
  • Thread starter Thread starter MadMax
M
MadMax
I want to record drums to my 388 and everything else direct to disk using Sonar. What do I need to do this?
You'll have to stripe track 8 with timecode, with dbx on track 8 switched off.
Then, you'd use the 388 as master, & have the 'puter software chase the timecode signal of the 388, with a timecode/MTC sync unit as interface between the 388 and the computer.
That's in very general terms, of course. Good luck.
umm..I forgot to mention, I'm an idiot. Can I generate sync from Sonar?
I think that's the function of the timecode generator/reader,
the sync interface unit, not necessarily the Sonar software.
You'll have to consult the Sonar manual for specifics on how to sync Sonar to external clock sources.
