How Do I Eliminate That Annoying Buzz Noise
  • Thread starter Thread starter datboylamar
D
datboylamar
I RECORDED AN INSTRUMENTAL SONG USING SONAR AND I DIDNT REALIZE THAT MY PATCH CABLE WAS DAMAGED UNTIL I WAS DONE.....WELL HERES WHAT HAPPENED WHEN I DID THE FINAL MIX DOWN OF THE SONG I NOTICED THAT I HAVE A BIG BUZZZZZZZZING SOUND GOING ON IN THE TRACK....IS IT AT ALL POSSIBLE TO GET RID OF THAT NOISE WITHOUT RECORDING?....WHAT TYPE OF EQ SETTINGS CAN I USE UNTIL I COME ACROSS SOME ONE WITH THE PROPER EQUIPMENT...
A notch filter or a variable high-pass may help, but if it's broader-band than just a tone, then you're going to have trouble removing a lot of it....
A stacked notch filter centered around 60 hz can help but it won't get it all. You're better off re-recording.
