jasonbmerrill
the end of unreality
i say the only real difference is space. Anything else can be overcome with time.
I agree with the "space" and "rental" aspect. Big studios (sp) have to cover their overhead (no pun intended) and offer a a turnkey operation with various amenities, including good coffee. Some are based around a particular engineer or producer. One aspect referred to earlier is the type of gear available. Some folks want a particular piece of gear eg. Studer 2 inch machine or fully digital, Pro tools, Radar etc.
It all depends on the budget, time alloted, location be it near or far and the vibe of the setting. to grind the old ax in a different way; you don't always get waht you want even if you payed for waht you think you were gonna get. Given the derth of quality equipment and the ready access to willing folks to record the "high end" studios are taking a beating. Nonetheless, the high end folks generally have spent a lot of time and money on the room and the desk and quality signal chain. Forgive spelling errors. I don't think the newest hot item or "rolling stones/Police etc. would really want to come to my place and record their newest release. Even though I make great coffee. Be well all.
Then there are Pretengineers who are hacks, have a ton of $$$ and just like to think they are great engineers.
If a standalone recorder is used like the examples you've given, how is it possible to mix properly with a decent DAW like pro tools? I know it must involve some way of transferring audio data into a visual format on an lcd monitor so using pro tools is possible, but how can this be done with audio that's only been recorded on a standalone multitrack console?
If the studio uses digital recording, yes mostly is a computer running protools HD or simiar, if not an analog tape recorder(s), or both. Its like a home studio, with more money, better sounding rooms, and nicer coffee![]()
Well, that, and torch/pitchfork toting wives and neighborsI agree, few home studios are even decent acoustically. Which is part of why many home studio owners feel the need to record midi drums.....
anytime someone asks i always say that, that "most" do NOT record at 192. everyone thinks im full of shit. glad to see someone else feels the same way.Sidenote: Around 70-80% of full-time professionals work at the target rate -- The highest possible sample rates are rarely used (and rarely the 'best sounding').
The pro studio could care less if your performance sucks or your engineer sucks. They make $$$ renting a turnkey operation.
Then there are some that are owned and run by an engineer who takes pride in his/her work and it is up to you whether you like their work.
I don't think I know anyone who actually records at 192kHz... I'm not sure if I've ever heard a converter that sounded decent at 192kHz for that matter. Well, maybe one or two...anytime someone asks i always say that, that "most" do NOT record at 192. everyone thinks im full of shit. glad to see someone else feels the same way.
lol wow no one really answered this kids question. So I will.
Well some studios record artist to 24 track 2 inch tape machines that they used before computers. With these machines you get a sound that gives you a much different quality then digital recording. Anyway with that all studios do is hook up a big analog mixer to the tape machine and use it to mix the tracks almost like a control surface.
Now when studios record right to protools they usually (not always) use again a big analog desk into an I/O that every track on the desk is outputted to so you can mix the audio signal from the desk and also record using the desks and other features. preamps
Some studios even record to tape first to get the signature tape sound and then send it back into pro tools for mixing.
I hope that answers your question a little better then these bozos.
(sorry for the grammar I am not in school so I thought I would let it slide but ive been criticized before so heres the disclaimer)
Short answer, you probably don't. You mix on an analogue desk, free from the distractions that a DAW provides. I'd love to be able to do all my stuff like this, but nowadays its far more costly to get started with than a basic digital setup like I have. I will admit, my digital mixes sound b*llocks, and I feel its partially because I get far too carried away with looking and tweaking instead of listening.
Nowadays its too easy just to add another plugin into the chain or be too heavy handed with a compressor plugin without listening carefully to what it gives or takes from the mix and concentrating on the feedback you get on screen (i.e. onscreen level meters - it sounds weird but I sometimes find myself adjusting levels and looking at the level meters on screen rather than listening), whereas with analogue stuff you have to think about your signal chain and don't have so many visual distractions. The one time I got to play with an ADAT system (yes I know, not proper analogue tape, but I'm thinking more of the mix method) for a few hours I thought "god this sounds good, I could actually pass this off as acceptably semi-professional-hobbyist quality!". I've also tried doing a mix on my PC where I use minimal/no effects and literally just 'mix', i.e. set the levels and be done with it, and it was probably one of the best sounding things I'd ever done.
And as always, a lot of it comes down to how well the parts are tracked - if it is done well then you shouldn't need to cut things up, slice things around and massacre them with EQ. Another bad influence of digital is that new people like myself take the lazy stance that 'you can always fix it later'.
Having said all that, some people do record onto tape just to get 'that sound' then bounce it to their computer to edit and mix on a DAW.
But I suppose you'd better have your outboard effects handy. I, and many others around here, use tape in my home studio. It's much cheaper than a supercomputer, two wide-screen LCD monitors, three interfaces and a control surface, and a lot more fun. Not to mention "that sound."
Well, there's analog mixing and there's analog summing -- And (of course) there's analog tracking and dumping to digital (a personal favorite).
Yes - when tested, over and over, I prefer analog. That's not to say that digital isn't absolutely wonderful... But on the rare occasions that I'm tracking and mixing, I'm generally tracking to 2" and pulling right off the repro heads to digital. Trying to "add tape sound" later almost always fails.
