T
traw
bounceback-stay_fresh.mp3 - 3.36MB
What Can I do to bring the vocals up clearly?
I used this as a guideline .
1. urs 1980 compressor, using the preset "Fairchile#1"
this works as a thickner
2. SSL Channel, using the preset "lead vox" and adjusting from there,
this is really the main plug in the chain, the trick is to boost hi, mid, low mid, and bass,
that way you will get a sound that feels as the original but has the sound of ssl.
remember to use low cut and adjust the compression
3. Waves Rcomp, using the preset "vocal"
adjust the threshold so it works your peaks, adjust the gain as high as possible without clipping
( a few peaks is allright)
you can use this chain on each vocal track with great succes.
if the sound is to hard try to bypass the URS and turn down the ratio and threshold in the SSL channel compressor
