starbuck26
or at least I think I was.
Here's the deal:
My Hot Rod DeVille was having some kind of weird static/popping noises. I consulted the trusty Hot Rod Owner's Guide and it said this:
An issue that commonly pops up in Hot Rods is the Plate Load Problem. These amps sometimes develop a loud intermitten crackle/static that's mainly caused by the 82K plate load resistor of the phase inverter (R57). Sometimes this resistor will come completely "open," or, in other words, it will internally break into two. This results in a dramatic loss of volume, as only one power tube is amplifying, and a terrible sounding break up even when the amp is supposed to be clean (i.e. severe crossover distortion). You can check for this by measuring the voltage on both sides of R57. If there's several hundred volts on one side, and zero volts on the other, then we've found the problem. If the resistor only partially fractures, then a crackle/static appears.
No need to worry if your amp is suffering from these problems, this fix is very inexpensive and simple. You'll need only to order the correct parts and replace them. Most techs go ahead and replace every plate load (R4, R11, R16, R22, R57, R58), which may be a good idea.
When asked about the problem a Fender representative said, "we had a vendor problem with these resistors. The problem would cause the resistors to eventually hair-line fracture and open under normal operating conditions. The vendor has since analyzed and corrected the problem with their process."
So my amp is covered under the factory warrantee, meaning I have to use a Fender accredited shop, but it'll be free. Which means that I can't go to the local amp genius working out of his garage, I gotta bring it in to this service center.
I bring it down there. I explain the problem. I read them the description of the problem. I am SURE it is the plate load resistors. I tell them very specifically that if they think it's any other problem I want them to call me before working on it. Meaning... if it's a tube related problem, NOT under warrantee, I want the amp back and bring it to my trusty guy.
They have it for two weeks. I call today asking if it's ready yet. He said yeah it's been ready for days (a phone call woulda been nice...
). Said it'll cost me $80. I said it's under warrantee, and he said "the warrantee only covers the tubes for 90 days."
The fucker replaced two power tubes AS WELL AS my plate load resistors. Why? They were old, I guess. . I have two brand new JJs sitting at my practice space waiting to be installed and biased by my trusty guy. So I say NFW. I'm not paying for it. He tells me I have to call tomorrow and talk to his boss.
I KNEW IT. That's the thing. When I dropped it off there I JUST KNEW they were gonna fuck me. I'm going to tell the manager to keep his tubes and give me my amp back. I don't even know what he put in there yet... could be Groove Tubes... Sovteks... This shit MATTERS.... right?
Is that reasonable?
Here's the deal:
). Said it'll cost me $80. I said it's under warrantee, and he said "the warrantee only covers the tubes for 90 days." The fucker replaced two power tubes AS WELL AS my plate load resistors. Why? They were old, I guess. . I have two brand new JJs sitting at my practice space waiting to be installed and biased by my trusty guy. So I say NFW. I'm not paying for it. He tells me I have to call tomorrow and talk to his boss.
Is that reasonable?
