But I was specifically referring to the width of the soundstage, not the dynamic range, frequency response or any other specification.
Soundstage is irrelevant. By the time a signal hits a recorder, analog or digital, it may as well be dual mono. It's two discrete signals (except for crosstalk . . . hmmm, is that better in digital or tape?). Let's dispense with the illusion of stereo, and just talk about a single mono track. If there is a flaw in digital, it can be exposed in mono. If there is a distortion in tape, same thing.
The truth is, tape-o-philes can't argue dynamic range, frequency response, phase response, or any other actual measurable specification, because they know they lose those arguments. So you have to make up things like "soundstage". Doesn't cut the mustard with me.
When people have fundamental differences in perspective they don’t tend to scan a person’s argument for things that actually make sense… because they don’t want it to make sense.
Wrong. You see, I am intellectually curious. When somebody makes a claim to me, I first think, can I test that? If the answer is yes, then I do it.
If you search my old posts, you will find very detailed analyses of attenuation of high frequency signals vs. sample rate; comparison of cassette tape, VCR, and a control sample of D/A/D, just yesterday, an analysis of the need for dither given a typical acoustical noise floor. Those are just three examples I can remember, there may have been more. Nearly every day, I am analyzing the performance of an analog circuit. That's how I feed the family.
So for you to imply I dismiss your arguments because I don't want to believe them is very mistaken.
And if you really want me to, I will analyze your silly evidence-free assertions too. I've done plenty of D/A/D transfers before; as I mentioned, I designed and built an analog summing cable (wasn't much of a circuit design, really, just a resistor) and did a detailed comparison of use of that product vs. digital summing. So I already know how well my converters perform on a variety of signals (yes, including program material). I didn't post that analysis for public consumption, but I will redo it if need be.
Are you, on the other hand, actually willing to do any work, in terms of a repeatable experiment?
Ok, about your Nyquest comment. The Nyquest Theorem is digital 101. I can’t remember a time when I didn’t know it. And it only addresses minimum resolutions necessary for achieving a given frequency response without severe distortion. The actual quality of that frequency response as perceived by the human ear (not test equipment) is open to the listener.
Wrong. Wrong, wrong, wrong, wrong, wrong, wrong, wrong.
First, learn to spell the man's name, he was a brilliant scientist and earned the courtesy. Don't dismiss his work as that of a digital hack, because he did it long before the era of digital recording, and the body of his work is the foundation of not only digital recording but analog audio circuitry as well.
Now, as to your misunderstanding of his theory: It describes the minimum resolution necessary for achieving a given
bandwidth-limited frequency response
without any distortion. The only caveat in a real world circuit is the effect of the antialiasing filter required to achieve that bandwidth-limited response.
For any modern converter, your assertion that 16kHz would be adversely affected is laughable. If you had said 18.5kHz or higher, I would have somewhat agreed, but in comparison with the Portastudio, that's just a joke. The Porta must be down 20dB at 18.5kHz, versus like 0.5dB for digital. I'll have to dig out my old graphs and check.
And what's even better is that if you switch up to a mere 48kHz sample rate, the 18.5kHz attenuation goes away, and the 20kHz is now down maybe 0.5dB. Portastudios can't do that!
Look up my old posts, the graphs are there. I've done the work already.
But advocates of higher digital resolution are already making that argument, so it’s as much a digital vs. digital argument as it is an analog vs. digital argument. The analog people could go away and it would still be an issue.
No, the real digital people decided long ago: something like 60kHz is an adequate rate to completely eliminate attenuation in the audible band (to 20kHz) caused by antialiasing filter attenuation. Anybody who says different has a warehouse full of 192kHz gear they are trying to move.
I don’t need to read anyone’s white paper.
Why? It demonstrates with real actual math everything I just said above, and what's better is that anyone with a converter can verify its conclusions for themselves. What's even better is that you really don't even need a converter; just spend an hour with an SRC plug and you can verify Lavry's theory.
That's science for you, right here:
http://www.lavryengineering.com/white_papers/sample.pdf
That being said, I don’t know that frequency response is the test to settle the issue. It is only a hunch among many thoughts I have as to why digital hurts some people’s ears.
Well, you know, I have already skewered your frequency response and distortion hunchs, so you need a better hunch, something we can test for ourselves.
Right now, all you got is that digital hurts because it doesn't distort like tape.
Let's try a test to see if you can distinguish a live source vs. a (reasonable quality) digital playback. Get a MIDI controlled grand piano, a mic, a pre, a converter, and an A/B/X switch, and see if you can distinguish between a straight analog feed and A/D/A. And make sure that you don't know which wire leads to A, B, and X
But your experiences and mine are just anecdotal nothings in the grand scheme of the analog vs. digital issue, which is universal.
Again, wrong. I have not argued a single anecdote, only testable, repeatable, verifiable experiments. You are arguing from anecdote, not me.
The results of your proposed experiments would be insignificant in light of the sheer number of people that already report a preference for analog for it’s pleasant handling of music compared to digital
To quote the best movie ever (EVER!),
Joe vs. the Volcano
I'M NOT ARGUING THAT!
Here's the fallacy:
1) Analog sounds better than digital;
2) Something that sounds good is more technically perfect than something that sounds bad;
therefore:
3) Digital is technically flawed.
I am happy to agree with #1. Mainly because I don't care! I have no desire to own a large reel tape machine, and that is what is required to realize your goal of good tape sound. Anybody who thinks a Portastudio has the same good qualities as 2" tape . . . I don't know what you are smoking. I've had a 424mkII for 11 years now. I like the little thing. I still used it as late as 2004. But to suggest it sounds either euphonically or technically better than my HD24 (which replaced it for live work), that's really funny.
But I am perfectly happy to believe that 2" sounds better than going straight to my converters. I don't know whether or not it's actually true, but because I haven't done the experiment myself, I keep my mouth shut. That's fine, I don't make my living from tracking, and I don't mind not having those nonlinearities adding to my recordings. Other people's stuff I work on is already analog source or not, no sweat off my back either way.
I make and sell analog gear exclusively, so I am hardly tied in to digital (except that it has greatly expanded my pool of customers). Everybody could buy a Studer tomorrow, and I think I could still sell them mics, so long as the interwebs (digital!) are still in existence so they can find out about me!
The giant flaw in the argument is #2. That just not true. Tape-o-philes that argue it are gonna get their pants pulled and maybe even an atomic wedgie! Which, I have to say, in 2008, they deserve!
I’m equally exasperated by members that know just enough about digital to be dangerous, but not much really beyond popular misconceptions. But, what we got is what we got on these anonymous forums.
Anonymity can bite me. My name is Jon O'Neil, I live in Kill Devil Hills, NC, and I am the owner and proprietor of Naiant Studio.
What else you got?
When I consider how analog benefits my sound and how I meet such hostility by simply sharing that information for the benefit of fellow recording enthusiasts
See, I was perfectly happy to stay out of this thread so long as you simply argued #1 (above). You will get no disagreement from me on that point.
It's #2 and #3 that got me involved . . . so enjoy the hostility (wedgie!)
